Wow check this oil leak....
So I picked up a few basket case 110's and got one together and looks nice. It started right up but I noticed an exhaust leak. Then about 20 seconds later oil started laeaking out of one of the exhaust bolts? I noticed when putting this together someone had drilled and tapped bigger and cleaner header bolt holes. So it looks like they went to far one way or another. My question to you guys is there any way to fix this? I do have two other 110 motors that have spark should I spend all the time and work replacing the motor or fixing the one I have. Is it difficult changing out the head/cylinder? Would I have to mess with timing and are there any special tools needed. Can I like someone suggested fill the hole 1/2 way with JB weld then put the bolt in while the JB weld is wet?
Thanks!
Tim
Coos Bay Oregon
1985 ATC 70
1979 ATC 110
1981 ATC 110
1982 ATC 110
1970 Ford Bronco
2000 Kazuma 50
