Results 1 to 8 of 8
Thread: 1985 ATC 110 continuously fouling plugs
    Aug 2011
    NE Ohio
    25
    Hi
    I just bought 2 three wheelers today, a 1985 Honda atc 110 and a 1979 atc 70. I started playing around with the 110 and got it to run. it runs good, but like the guy i bought it from said, it fouls plugs. if i turn it off, i have to take the plug out and clean it before i can start it again. Any ideas on what could cause that? i'm thinking it might need new rings.
    Also, it has the hi-low sub trans and i cant seem to get it to work in the hi position, but it runs in the low setting.
    If anyone has a digital copy of the manual that would also be much appreciated. I will get pics up here soon.
    Thank you in advanced.
    -Michael
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    First off, does it smoke when running? If so what colour?
    Whats the condition of your spark plug after running it? Is is just dry black or wet black or puffy black?
    Either of those top 2 answers will tell us if its burning oil...(new rings and valve stem seals might help) If not then it could be from running rich, if so a simple carb adjustment might be nessisary to resolve your problem.
    Sarnia, Ontario, Canada
    3,415
    Check engine compression..you got a burner!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Aug 2011
    NE Ohio
    25
    thanks for the responses, it doesn't really smoke, maybe a little white smoke if revved high for a while, but i wouldnt really say it is smoking.
    the spark plug is a combination of wet black to dry black, but mostly wet.
    i never thought about it running to rich, maybe that's the problem. if it is, how do i adjust the carb to fix that?
    Jun 2011
    Louisiana
    31
    check the air filter and check your float height and make sure your float isn't sticking. If that doesn't do it, you'll have to start playing with jets
    Apr 2008
    NW, IND.
    842
    check for weak spark also.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Mar 2007
    Texas
    5,045
    do a complression test, then rebuild the carb. you probebly got worn carb parts that are allowing it to dumb fuel into the engine. This is a common problem. rebuild kits withthe correct "preformed" bowl gasket usually run about $25 shipped from ebay. and have all the parts you need.
    ________________
    https://www.mikesatvfix.com
    Aug 2011
    NE Ohio
    25
    thanks for all the response, so today i took the carb off, and cleaned it up. It runs a whole lot better now. I still have a few problems though, invlolving the transmission. The first is the sub transmission doesn't work in high gear, but is okay in the low setting. any ideas on how to fix that?
    also, the transmission makes a little noise every once in a while, but im not sure if that's the hi-low or the actual transmission. i dont mind working on the sub transmission, but don't really want to open the bottom end of the engine up unless nescessary.
    Thanks
