Results 1 to 13 of 13
Thread: What would cause a weak spark?
    Apr 2009
    Oklahoma
    1,234
    What are some causes of a weak spark?
    Sarnia, Ontario, Canada
    3,415
    High resistance in your coil, weak or improper gap at your pulse generator, failing ignition module, bad ground on coil, high resistance in spark plug lead, improper plug gap, stator failure or grounding issue...I probably forgot something.
    Take your pick. The Honda manuals on the site have pretty good troubleshooting..provided you have a multi-meter.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Scootertrash's Avatar
    In the sticks
    4,638
    Not enough exercise?
    Apr 2009
    Oklahoma
    1,234
    Im gonna start with the ground issue first Ill keep ya updated
    A weak coil, dirty magnets, bad ground - all the usual electrical issues......
    In the sticks
    4,638
    I was told many years ago that the majority of electrical issues can be traced to bad grounding.
    What makes you think you have a weak spark?
    Apr 2009
    Oklahoma
    1,234
    Well i will hold the plug in my hand and pull the recoil and I have to pull it real hard just to feel a tiny spark in my hand. There's not even enough to see it ark off the frame.
    Husky250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    NE Ohio
    264
    Quote Originally Posted by tulsamike3434 View Post
    Please tell you're joking?
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Deffinatly check your ground before tearing into it, if nothing's obvious then i would change your stator coil.
    It happened to my 200s when i first got it, weak spark then would shut off when hot... pull it again no spark, did some reasearching and found ''common problem with stator coil'' there only 25-30$ new.
    Apr 2009
    Oklahoma
    1,234
    Quote Originally Posted by Husky250 View Post
    If you can't see an arc how else would you tell?
    Apr 2009
    Oklahoma
    1,234
    Quote Originally Posted by 1984 honda 200s View Post
    I have like 10 coils and used them all with the same result.
    Nov 2010
    446
    Well if you changed it with the same result, what ive done before to was cut 1/4'' off the end of the plugg wire at both ends, sometimes the ends get burned or dirty..
    I absolutly forget who told me this before, it was a member tho!
    Sep 2007
    100mi west of Chicago
    3,582
    Make sure your boot is screwed on good. I will sometimes cut just a bit off and screw it back on
    Rob
