Results 1 to 3 of 3
Thread: 85 atc running rich
    Mar 2012
    Oklahoma
    12
    85 atc running rich
    whats up, picking up a honda 1985 185 and supposedly its been bored over to make it a 200. but its running rich and fouling out the plugs. last time i rode these honda three wheelers i was like 7 and im 23 now. im looking for a project and this is one thing i would really enjoy and bring back memories. any ideas on what to check in to?
    Mar 2012
    central mn
    13
    burning oil or air fuel mix too rich? If its burning oil and smoking then a overhaul is the obvious answer. usually the air/fuel needs to be WAY off to foul plugs in a 4 stroke, check all simple things over first, make sure air filter is clean, fresh fuel, new plug, open carb and give it a good cleaning and make sure no parts are missing.
    Nov 2011
    Northern Wisconsin
    16
    Do everything tri moto man said. Also, make sure it is jetted correctly, if you bought it from somebody in a different altitude or weather conditions that is probably the problem. There is a thread specifically on carb jetting, you should check it out it has a lot of information in it.
