Thread: ATC 110 horsepower update
    Dec 2011
    Oregon
    7
    I have an 83' ATC 110. It was really slow when it was bone stock. I looked up stock HP ratings and found 110's come with anywhere from 8-12 horses. I threw my 100% bone stock 110 up on the dyno and ran it. The results were 3.7 horsepower and 3.7 lb-ft of torque. I was pretty disappointed considering what people say they were supposed to have.
    Anyway, I ported the head out and made another run and it was 3.8 hp and 3.9 lb-ft torque. I rejetted it and the power/torque was the same. I jetted it up untill it was blubbering rich. But the thing that woke it up was removing the airbox lid, what a difference!!(it no longer ran blubbering rich with the lid off; it ran crisp and clean)
    But I didnt stop there, I put a K&N filter on it, Lightened the flywheel, Lightened the clutch assembly, and ground out the timing advance to change the timing curve to increase the topend power while retaining its low end power and built a 1" exhaust. Put it back on the dyno and ran it, The power was 4.7 and the torque was 9.7 lb-ft. Huge inprovement on torque and the seat-of-the-pants test reflected it! The best part is that all the power was made with stock parts so it's a sleeper! The throttle response was greatly imporoved as well.
    My brother has a 79 110 with a big bore 123cc high comp. piston and mine walks all over his.
    Just wanted to enlighten you guys on the possible power/torque improvements with the 110.
    Blossvale NY
    4,563
    Cool! Now I guess I have some modding for my some and I to do on his '85 110!!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    6,819
    This is all rear wheel HP ratings correct ?
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    can u post pictures???
    Mar 2012
    central mn
    13
    How do you grind out the timing advance? is than something you can do on a 185??
