Results 1 to 13 of 13
Thread: newest addition to the "herd"
    Mar 2011
    Red Lion pa
    1,542
    Pushed my luck with the "boss" and picked up an 85 250sx last night. Not perfect by any means but functionally seems sound. Said he had just had the swing arm bearings changed and oils serviced. Fires right up with starter, lights work, tires hold air. First one I brought home that really doesn't need anything prior to riding! Stitched front fender, a makeshift drive shaft boot, and an epoxied tank. All functional though. My only question at this point is the rear rack the one made for this model? Rack ends up not allowing the trunk lid to be opened. Thoughts? Only down side was the "boss" did hint around about "thinning the herd". She just don't understand! Click image for larger version.
Name:	3 wheeler 001.jpg
ID:	143118Click image for larger version.
Name:	3 wheeler 002.jpg
ID:	143119Click image for larger version.
Name:	3 wheeler 005.jpg
ID:	143117Click image for larger version.
Name:	3 wheeler 003.jpg
ID:	143120Click image for larger version.
Name:	3 wheeler 004.jpg
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Holyrood Newfoundland
    114
    Nice bike might want to flip the back tires. Is that muffler loud?
    Honda
    1985 Big Red 250-Sold
    1985 200m-Donor
    1984 200m-Parts
    1992 cr125r-Project
    1983 Auto X
    Yamaha
    1984 Ytm 200-Sold
    1999 Yfm 350-Traded
    Suzuki
    1992 lt250r
    Mar 2011
    Red Lion pa
    1,542
    Yea seen that too this evening while snapping pics. Probably whoever did the swingarm bearings swapped them when putting everything back on. It's actually just an exhaust tip he bolted onto the original muffler. He had a cooler type bag that went over the rear rack and he said he wanted to dissipate the heat further away. So its no louder than stock. Looks cool though. lol
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    OK
    5,450
    Quote Originally Posted by MRSOUND View Post
    That's why I tell my wife they are for her.. My wife has more 3 wheelers than I do.. lol
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    114
    Yeah it would make me feel better about buying a bike from a guy who actually seen problems like that and fixed them instead of just hoping it worked out.
    Honda
    1985 200m-Donor
    1984 200m-Parts
    1992 cr125r-Project
    1983 Auto X
    Yamaha
    1984 Ytm 200-Sold
    1999 Yfm 350-Traded
    Suzuki
    1992 lt250r
    Mar 2011
    Red Lion pa
    1,542
    dcreel - just tried "giving" her one......didn't pan out Oh well guess that means I need to get on my projects and get them done and sell whats left of the parts bikes.....(then I'll have more room for another!)
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    andersonee4's Avatar
    andersonee4 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ames, Ia
    169
    check rear end oil. Check axle tube bearings. You may just save it by checking it.
    Beaver Falls, PA
    2,666
    Looks to be a solid rider, nice pickup... that rack is very similar to one that was available for the sx, but if the trunk lid doesn't open, it's probably the same brand of rack for a different model and someone "made it work"
    Mar 2011
    Red Lion pa
    1,542
    Is it possible it's mounted to far forward? Haven't looked at closely yet. Is there any adjustment front to back? I need about an 3/4" to 1" moved toward the rear for it to clear.
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Beaver Falls, PA
    2,666
    It bolts onto your grab bar, so unless you moved THAT...
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    This rack look exactly like mine. Not a single difference otherwise than its red. My trunk lid will open but will a little lid bending to make it go over the rack bar.
    I think thats a stock SX rack. I know mine is a stock rack. You might wanna look in my gallerie to compare...
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Mar 2011
    Red Lion pa
    1,542
    Thanks ailll1.....I did compare and they look to be identical. Like I said it won't take much (along with a little flex in the lid as you mentioned) and I could get it open. I believe I'll try and loosen all the mounting hardware and see if I can pull towards the rear any to give me enough clearance to at least access and utilize the trunk. Thanks again for pointing towards your pics!
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 red
    85 klt 160 (Floyd)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    malibulvr's Avatar
    malibulvr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Lockport, NY
    203
    Women just do not appreciate anyting that makes us happy...LOL. Very nice looking bike!!
