Results 1 to 8 of 8
Thread: Can I use this 200x brake piston?
    May 2009
    S.E. Michigan
    1,251
    So DRKCYDE and I are rebuilding the front brake caliper on his 200X. We know about the replacement calipers from other machines, but want to try cleaning up the original.
    In pushing back the piston into the caliper, the c-clamp punched through the outer face of the piston. We though it was toast, so we gave up. Later, I totally disassembled the caliper and poped out the piston and realized that the part we punched through was just a sort of pad on the front surface. The piston is still totally sealed up and intact behind the cruched part.
Name:	Piston 2 (Medium).JPG
ID:	143142Click image for larger version.
Name:	Piston 1 (Medium).JPG
    So, basically, does anyone see a problem using this? It obviously needs to be cleaned up, but should it still be ok to use?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    The damage you did to it, is probably minor and would be fine to use, but looks like it might not be salvageable in other ways from what i see in the pictures it looks very rough.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    May 2009
    S.E. Michigan
    1,251
    Yea, the rest of the piston isn't the greatest... the pics do make it look worse than it really is, though. I'm going to see if I can clean this thing up before ordering any other parts.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Texas
    137
    If there aren't any large gouges or scratches on the outer surface (where the seals ride), it should be OK once you clean it up. Small scratches can usually be taken care of with fine sandpaper (800 - 1000 grit), the important thing is for the outer diameter of the piston to have as smooth a surface as possible to prevent leaks between it and the seals.
    TRX 70 - rescued from the trash
    84 125m - first restoration
    84 200m - now a four wheeler with 450r suspension
    84 200x - restored, now my rider
    83 250r - current project
    Looking for an FL350 (Odyssey)
    NEPA
    7,051
    Total garbage. Do not even consider using it ! Yes,,,it could be polished and shoved in,,but it will never be right. At the least,,have it rechromed !
    May 2009
    S.E. Michigan
    1,251
    Quote Originally Posted by atc007 View Post
    Total garbage. Do not even consider using it!
    I think you guys are right... it is pretty rough. Given the cost of some of the replacement calipers from other machines (don't have the thread, but from a dirtbike) it probably isn't worth the trouble.
    Thanks for the opinions, guys.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Nov 2007
    the front brake from a 80cc honda late 1990's I think. Direct bolt on except you lose the parking brake. I run this setup on my 84 200x that I had up at rose city last year.
    It does look like junk.
    Many I can wrap paper around and gently chuck them up in my lathe, then flip them and do the other side. But thats just very light scratching that super fine emery cloth and WD-40 take care of. I love the CR plastic or resin type pistons.
    They don't move much throughout their life in a set of decent pads.......
