Results 1 to 8 of 8
Thread: finally opened it up
    Jun 2011
    southern california
    125
    so i finally opened up my 300R head and this is what i found Click image for larger version.
ID:	143158Click image for larger version.
ID:	143159im not to sure what to be looking for since im kinda new to this but what do you guys think
    OK
    5,450
    Time for a top end.. That head needs smoothed out or rechambered too.. See all the pieces missing from the edge of the piston? Those flying around dinged up the combustion chamber of the cylinder head.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Mar 2008
    EastGreenbush, newyork
    3,494
    looks like ya had some detonation going on in there for sure!! atleast the piston didnt melt, so your lower should be fine. what octane fuel do you run?
    Mexico
    9,018
    I'm guessing a little detonation was taking place in there to have started the deterioration. What kind of fuel are you using?
    Jun 2011
    southern california
    125
    i actually have never used this i bought it from a guy for 100$ with another engine and a bunch of other random parts a little wile ago and want to rebuild it and put on my 81R i have been reading about it and was thinking that the deck mod would be the be easiest way to go i think the sleeve actually looks good just some small scratches and nothing that catches my nail
    Blossvale NY
    4,563
    Also, I have seen where a failing lower rod bearing does this kind of damage. Check your crank and lower rod bearing thoroughly before running that new topend!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    NEPA
    7,051
    More often than not ^^^
    Sarnia, Ontario, Canada
    3,415
    A nasty bit of el grenado there...
    I see dead presidents!!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
