Originally Posted by
CrossadaMan
The bike is almost new, no rocks or dots in nowere, and plastics almost new. I think this bike was of a fireman, that use it with Farm Gas/oil like the old ones. I take out the muffler and if i shake it, it make a sound of liquid inside, but it does not get out, even with air compressor. Maybe the problem is that the exhaust and muffler are full of black greasy oil, and there is nothing wrong with engine.
How can i clean the exhaust and muffler, and take out that oil from inside? Put gasoline and then burn it?
I will buy the crank seal to change it to eliminate possibilitys. Can you tell me if i can change it, without taking off the clutch and clutch plate ?
Best regards
