Curtis,
First, lets try to keep it to one thread to keep the confusion down. It's also easier to track your progress.
Go here
http://www.3wheelerworld.com/showthr...Jetting-Theory
and print out the instructions for jetting and take them out to your garage with you when you do this. It will help you learn the procedure and the results from each change you make to the system.
Is the air filter clean? When was the last time the carb was cleaned thoroughly? You may need to take the bolt out of the muffler and remove the baffle to be sure it's clean.
You need the machine to idle without the choke first before you can continue. Make sure your idle jet is clean, don't assume that it is, verify that it is. Set your pilot screw to the factory setting ('83 - 1 3/4. After '83 - 2 1/4.) Leave the 110 main jet in and set the needle to the middle groove. Put the slide back in and tighten the cover. Make sure your throttle cable is adjusted properly. Put the airbox cover back on. Start it and warm it up to operating temp in your driveway. Once it's warmed up see if you can get it to idle without the choke by using the idle speed screw on the side of the carb. If you can get it to idle then you can fine tune your pilot screw before you test ride.
Take it for a test ride and see how it runs, then follow the jetting instructions in the link above or post back here. I'm laid off and around generally most of the day, I'll check in to see if you need help.
Jetting can be frustrating. Be patient you must young Jedi!!
