Results 1 to 7 of 7
Thread: 1983 Honda 200ATC Brakes
    Mar 2012
    Tyler
    7
    How do I remove the rear brakes? I have the wheel, outside cover and large nuts loose, but can't get the drum off.
    Mar 2012
    Toronto, Ontario
    27
    wd40 and patience
    Mar 2012
    Tyler
    7
    Thanks...was hoping I had just missed a clip or something.
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    there is an o-ring on the out side of the drum and also loosen your breaks if they've worn in enough into the drum it will not come off make sure the axle turns while your taking the drum off
    Mar 2012
    Tyler
    7
    I appreciate your assistance.
    Pacific NW
    4,255
    Quote Originally Posted by DJC View Post
    Free manuals in the 'world class help' section BTW.
    The only brakes I can remember are 1985 sx/es and they were like a car drum with 2 phillips set screws holding the drum on.
    x2 with wjg
    For some reason, the orig factory lube on the brake actuator turns into some sort of sticky film and keeps the shoes out, maybe just enough to bite into grooves in the drum.
    The search key has save me many times, especially when everyone is out riding.
    You should be able to access tons of info about 'stuck drums' or some other key words
    with one click.
    Feb 2012
    Mount Joy, Pennsylvania
    63
    Had the same problem with my 84 200s. A lot of patience, pb blaster and I tapped around the drum with a ballpean while pulling on it. Slowly it came off a cm at a time. Took me bout an hr and a half
