Can a Honda 125m motor go into a honda 110? Or is there some modding to be done?
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
yes it would, but you'd have to find a place to mount some of the 125 elec stuff on the 110 frame. i think that's about the only real differance besides the chain tensionor and batt if i'm not mistaken.
Hopefully someone will post.
I'm trying to go the other way.
I have a 125m with a non fixable case but tons of 90-110's.
I do remember something about the 125m plastics and seat being different because of the
charging system stuff and E start.
I wonder just how different the wire harnesses are.
Might have to swap those too, idk.
Weather sucks right now and nothing outside is fun.
yes it'll work the other way too. i'd say it's actually easier to go the other way since you'd be losing some of that elec stuff.
As far as i know they will not. Or atleast the topends will not swap, i can't remember anymore......
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
Somebody on here knows for sure, I remember this being discussed recently. My initial thought the last time this was talked about was "Of course they'll swap, they're almost the same motor". I'm glad I didn't post that because I'm pretty sure there are a lot more differences than one might imagine. Somebody will chime in soon.
If the 125 is the lay down style motor like the 110, then they go right in
yes they are both laydown
Correct, motor is a direct bolt-in, but it has extra electrical parts for electric start, etc.
right, i should've said extra parts.
if i remember right the topend's won't just swap around either like jason said. also you guy's might be thinking of the 86-87 125's too, they were vertical engines.
Do you have to use all the ele or just the main wires?
personally i'd swap it all over. motor, harness, controls and all if you can. it'd just be simplest and easiest really.
