Some daytime pics... and like a dumb azz i put the headlight on and forgot the throttle cable lol I guess I just get to excited
My ridez 110,110, Big Red, 185s, 70, 200, 250r!!!!
REQUEST YOUR ATC PART'S @ The 3 & 4 Wheeler Emporium
Reminds me of the one I did.
WOW looks nice!
Got my new plastics in today!
Well I ran into a problem with the seat...
BAD BAD rust holes what should I do I would like to find another one but any ideas on fixing this? I am afraid my welder will just blow through if I rey to fill in the holes,
what do you think is it trash?
Where the hell's your safety glasses? You only got two of them, you know! This was my solution cause looking for a pristine seat pan is like looking for gold. First I sandblasted it then I painted all the rusty areas with this stuff. Then I gave it a couple of coats of paint and handed it off to my upholstery lady. If the outer edge all the way around is good and the integrity of the mounting studs are solid, use it. If not, throw it in the trash and get on ebay!
I can not find notta on ebay.
Please someone can you help me find an after market seat pan
I found some plastic ones thank's...
now onto the tank...
I am going to do some testing on an old 110 tank for sanding. I want too see how smooth I can get it with my angle grinder.
Before....
and I will post some after I do it I will be useing some 120 pads to start then do the rest by hand...
on the real tank I think I will have to use some of this...
http://damonq.com/TechSheets/Red-Kote.pdf
I have used Red-Kote before and it works great!!!!!!!!!
I would use a stripper or even a da sander.The metal isn't that thick,plus if there is corrosion.There is alot of good info here on how to take care of the inside of the tank.Also spray paint won't last on the gas tank,the gas will eat it up.
vinegar is a waste of time. i did it for 7 days rotating sloshing and cleaning vigorously. then used baking soda to neutralize it several times. about 2 hours later.... tank was rustier than before!!.
1985 Honda 250sx. Ground up rebuild. SOLD
1986 Honda 250es Big Red with custom plow
Don't waste your time, or time will waste you.
Red-Kote makes it like a new tank again! even fills holes up to BB size.
Well i am painting my tank today..
live video feed
http://ustre.am/Il5U
