oil leaking.. ahhh
So i found out my big red is leaking oil.. and also found out that one of the holes for the stator cover to bolt it down is stripped.
what can i do to fix that? the only thing i can think is to re-tap it. also, the stator sover seems to have no gasket
looks like forma gasket was used. Also, whats the best way to make sure a case is dry of oil, so it seals right?
1987 Honda FatCat -Gripper seat, +1 front sprocket
1987 Honda TRX250x- Suppertrapp IDS2, +1 front sprocket, DuraBlue axle, HotCams, 10:1 piston, +2 widened
1983 Honda 200e BigRed-Has a ViseGrip for a shifter, 'nuff said.
1971 Honda Trail 90- Original Everything
Previous Rides:
1981 Suzuki TS100
1990 KTM 300exc
