Results 1 to 2 of 2
Thread: Good transmission? Bad transmission?
    Nov 2011
    Canada
    221
    So im wondering if there is any way to tell if a transmission is good or not just by shifting through the gears while it is parked. thanks.
    Blossvale NY
    4,563
    I have seen transmissions that seemed to shift OK when parked with the engine off, and then malfunction under a load. It can give you an idea, but the best way to know for sure is to run it through the gears under load.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
