Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Anyone Else Bench Run a Motor?
    Cold Lake, Alberta, Canada
    3,019
    Thanks web. My boy said my K0 US90 did the same thing when we first started rode it with the shifting issues. It also cleared itself up. I'll leave that alone for now. I opened up the subtrans on motor number one and some teeth fell out. Motor number two ran good, shifts OK and the hi-lo works...but there is a broken case bolt and it leaks oils from various locations. I swapped out the sub trans parts into motor number one only to find out the case is cracked from a chain being thrown at some point in time. So it's off to eBay for a gasket set to make two into one.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    jr315rn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    rochester ny
    288
    anyone ever make a stand to hold the motor, i would like to make something so it holds the motor pics and info would be great
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    I dont know if anyone has said it maybe they have, but if they havnt already, for the shifting problem your having, u might have to check the shifting forks inside thats the problem with you having to shift a few times for it to catch gears, thats whats wrong with my sons 70 right now, Shifting in insanely hard to shift and it pops out of gears at times.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Mar 2007
    Texas
    5,045
    once you get the harness or partial harness with the the cdi attached, then you can jsut spray carb cleaner into the intake w/o a carb and it will run off carb cleaner. you can spray cleaner down the intake to keep it running too.
    ________________
    https://www.mikesatvfix.com
    May 2011
    rochester ny
    288
    ???? anyone have pics
