Results 1 to 10 of 10
Thread: Do All Atc 70 Rub Front Fender ?
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    I Have Notice In A All Lot Of Atc 70,That There's Holes Or Scracthes From Front Fender Touching Motor Bolts...Is This Normal,..Does It Means Frame Is Bend?; My 70 Does Same Thing,It Was Like That IWhen I Got It... :o
    Apr 2003
    Bay Area CA.
    2,638
    mine doesnt, and its not supposed to, the frame is probably slightly bent.
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    I have a 1981 ATC70 and it does not rub either. 350XACC is right, the frame is bent. Usually under the gastank, generally due to somebody running it into a fixed object, house, tree etc. I'd say 60% of the ATC70s Ive seen on Ebay are like this. Some on Ebay have even had the lower half on the fender cut off so it wont rub. I have see them bent back out then welded/gusseted to add strength.
    Aug 2003
    290
    [quote="generally due to somebody running it into a fixed object, house, tree etc. [/quote]
    Bet That Hurs.. :-D ..
    This issue drives me crazy, being a 70 nut and all, anyways it can also mean the forks are bent as well. As a matter of fact more often it is the forks and not the frame. But check both. Also the famous dented gas tank, very common. This is the little tab that is gone or destroyed. This is an easy fix and will save future gas tanks. I always wonder if the kids or the adults are the culprit in the crash. After a few adult beverages the gloves come off and the 70's come out........who knows?
    Aug 2003
    290
    what's the best way to check if fenders are bend ?
    It wouldn't be the fender (more than likely) that is bent it would be the forks or the frame. The owners manuel, aftermaket manuels and the factory service manuel does not cover this issue in any way. Its rather easy to tell, if the fender hits the motor, well you have a problem. Forks are cheap on e-bay and an easy switch, also a good time to repalce those crapy little balls they call bearings, with some true tapered rollers, plus not a bad idea to check the front axle seals and bearings while your in there. Anyways if its the frame its time to decide on how you want to deal with that. Now there is a small chance that the fender is messed up but that is very easy to check, just look at the four mounting bolts on the forks and the condition of the fender itself, any rips, tears, movement, etc....than deal with that first. Fenders are cheap off of ebay and the aftermarket ones are fairly cheap and Honda still makes the front for around 30 bucks and its very nice. Aftermarket is available in red, blue and white, for around 24 and up. Used well? Hope that helps alittle.
    Aug 2003
    290
    My Bad,,,,I Mean To Ask For The Forks, Not Fender ! :oops:
    You will probly need a frame jig of some sort, streghting up frames are not that big of a deal, I have it done on the race cars all the time
    Aug 2003
    290
    Acutally,I Think Fenders Came Of Another Bike Cause They Are Not Rubbing,But,There's Holes & Scrachets From Touching Bolts...I Think
    That That Was From Before,Or Like I saiad,Fenders Came Of Another Bike.
