Thread: 250sx one way clutch advice
    Abrams, Wisconsin
    739
    ok, so my 86 250sx has been gradually getting worse in the kicker department. by the research i've been doing this is likely the one-way clutch bearing. (thanks 3wheelerworld!)
    my first question: does it seem likely this would also make a squealing/grinding kind of noise, intermitently, once the engine is running?? thats a new one, just started yesterday. trike still runs, shifts, drives fine. it has made the noise while riding, and while just sitting at idle. sounds like it's coming from the tranny/clutch area, so i'm guessing it's that clutch bearing getting worse. thoughts?
    next question: does service honda's site give the actual honda part #? or is it their own stock number?
    the reason i ask is i found this one http://www.ebay.com/itm/Starter-Clut...94273771257446 on ebay cheap, and service honda lists the same part# for the atc and trx, but the seller says this part replaces a different honda part # than the #'s listed on service honda's site. i know the oem is prolly a better part, but i'm on a budget. thoughts?
    thanks a bunch guys!
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Apr 2009
    Saskatchewan
    119
    Pretty sure that ebay one is for the other side behind the flywheel. You want the one behind the centrifugal clutch on the other side if your kickstart won't grab.
    Abrams, Wisconsin
    739
    whoa, didn't realize there was more than one. hafta study the exploded views better. thanks!
    anybody got thoughts as to whether the noise is likely to be that clutch?
    another 82 110
    Abrams, Wisconsin
    739
    Bump, anybody else?
    another 82 110
    Southern MN
    1,875
    The only thing I have noticed when my one way bearing went out was when I shut the machine off, I could still hear the cent. clutch winding down for several seconds until it cane to a stop, and then made a click noise. Does yours do this? The other symptom is going down a steeper hill. If your in gear, and rolling down the hill, it will almost be as if you are in neutral and roll freely, but when you hit the gas at the bottom of the hill, the clutch engages. I dont recall any problems intermitently when the engine is running though.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Abrams, Wisconsin
    739
    Hmm, it does make the clicking noise when i shut the engine down. However it compression brakes fine. Mostly the kicker will fail to catch sometimes, and this wierd new noise. It just seems to happen randomly.
    another 82 110
