^ pretty much right there. i shouldnt be posting this in here since this is about a (dirtbike)but im just in a pinch. its one of them with the points and stator all in one and right now i cant get spark
1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
1982 honda 200 bigred cobra exhaust
1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
what model bike?, if its not destroyed you can sometimes just buy replacement coils, then again it depends on the model
TRIKE INTERESTS
A1/A2 TECATE's
BIKE INTERESTS
ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
My Feedback
1972 yamaha dt2 250 enduro
Very simple. You SHOULD get new points,,but probably no need to. Get a points file,file the points shiny. Doesn't take long. CLEAN the points by turning engine over till they are closed. Pry open insert a CLEAN piece of paper to clean them. Set them to the recommended air gap. .17-.20 if you can't find the exacts. 99% of the time,this will give you beautiful spark. I've done this more than once ; )
ok. sounds like a plan. cause the points auctaly give it the spark correct?? the other coil things are just for lights? also whats the best way to wire this to just get it to spark/run since all the wires are buggered up so i dont know what goes where.
Correct,brass is lighting. Points make fire,condenser absorbs the ark. Coil turns it into High voltage and fires across the plug gap. Pull your plug cap off and trim the wire back fresh a 1/4 inch. She'll run. This should prolly be in the 2 wheel section : )
yea lol. i posted in there once before a while back with no respons sorry trike guys.
