Results 1 to 10 of 10
Thread: 1996 yamaha wr250 motor knocking?
    Dec 2011
    Missouri
    30
    I just picked this bike up last night. It runs great starts right ip and cant keep thebfront end down. But left side by clutch cover it sounds like someone is kicking like when i am cruising around and in a low rpm and i give it throttle it starts making that popping/ tapping noise. Loud i can hear it over the motor. But the bike runs great. I just changed the oil and it was veru dirty(dark black/gray) i was told its the crank bearings? Just dont want to keep riding it if it is somethong mayjor. Any help would be appreciated thank you
    Aug 2009
    Chesterfield, Virginia
    845
    Its likely if it was crank bearings the port timing would be off and not run or start great, its still a possibility, but since you say it runs good it may be piston slap to much space between the piston and cylinder from wear or over honing making a tapping sound) either one is not good, if you ride it with a bad crank it will eventually come apart, if you keep slapping the piston it will eventually break into pieces and likely drop to the bottom and ruin your crank, or tear the cylinder up. The best thing you can do is pull the head and investigate.
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
    PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
    1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
    My Feedback
    Dec 2011
    Missouri
    30
    Thanks for the reply. Well the noise comes from were the clutch is.
    Aug 2009
    845
    loose bolt at one of the clutch springs hitting the inside of the case? Bent main shaft (I rebuilt a blaster that had one)
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    My Feedback
    Dec 2011
    Missouri
    30
    Yeah possibly. But it only does it at low rpms. Could it be my front sprocket being worn and popping?
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by 3wheeler80 View Post
    the problem with that is you said it comes from the left side... the clutch is on the right side
    Dec 2011
    Missouri
    30
    no my clutch is on the left. and i dont think it is the motor knocking . i think its just the clutch going out or yeah something in there is loose or broke. (my clutch hops a lot, like a car)
    Dec 2011
    Missouri
    30
    My fault it is on the right. It does it the whole time. Idling and through every gear. I dont want to tear it down as ive never tore into a motor
    May 2011
    eden,ny
    3,481
    so is the noise from the left or the clutch side? A stethascope will pin point it (I think harbor freight even has them) in a pinch a 2' length of a broom stick will work.
    Dec 2011
    Missouri
    30
    i traded it off. it was the lower crank bearings and i didnt want to split the cases
