Thread: 85 200x kicker gear problem ?
    200xman123 is offline Quote: "sorry im not the sharpest tool in the shed" Arm chair racerFirst time rider
    hartford vt
    171
    ok guys finaly got my 200x started and running good with the 12:1 piston but after i got it started i shut it off to do the break in and when i went to start it again i kicked it and the kick lever jamed up so i pulled the little kicker cover off and the driven gear (the one on the left) had broke 2 teethe any one know why and do they make tougher gears?
    Baltimore, MD
    6,088
    I know why. 12:1 piston, 25+year old parts. The system is only as good as the weakest link. This is what happens when you go hopping up this old stuff without going over it real well. There will be other parts that will break as well, expect it. LOL
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Jun 2009
    Tunkhannock,Pa
    904
    Quote Originally Posted by 200xman123 View Post
    I may have a gear i could sell ya id have to look
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    6,793
    Are you sure you lined up the DOTS ...... correctly . if their off its crunch time . every kicker gear / shaft has a punch mark .
    hartford vt
    171
    the lines werent lined up ! darn it thanks guys for the info
