Results 1 to 10 of 10
Thread: 83 250r No 2nd Gear
    Feb 2012
    Alvin, Texas
    72
    83 250r No 2nd Gear
    Need some advice.... I found an 83 250r for sale ($400 o.bo.) that runs but is missing 2nd gear.
    I have only seen a picture of it, its dirty, missing the headlight, seat is beat up, but it does look
    complete.
    What could be the issue with the gear?
    Would this be something to look at?
    Looking foward to your opinions.
    Blossvale NY
    4,563
    When a transmission doesn't function in all gears it will likely need at least the gear that doesn't function and the corresponding shift fork. That is the most likely cause. Sometimes the shift drum needs replacing as well.
    This repair will require complete dis-assembly of engine and is a fairly involved job. But if you have mechanical ability and a good service manual to guide you along the way it's not bad. The question is how available the parts you would need are. I know transmission parts out of a liquid cooled R ('85-'86) are not the same. Not sure if the earlier '81-'82 models parts would interchange or not.
    In some cases you are better off to replace the whole transmission with one that is known for sure to work.
    I'm not sure I would part with $400 for a rough '83 with a bad tranny. Yes, the transmission is bad and I would elude to that fact and try to get it for $300 or less if I wanted it.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    connecticut, united states
    46
    I bought mine with no second gear. The gears are discontinued and what happened with mine is the tree teeth on the gear that slide into the gear next that Lock the gear in wore out. I welded up the teeth then spent time with a grinder till it was just right. That was 5 years ago and haven't had an issue since. But 400 is kinda steep for a beat up fooler talk him down 300 would be more correct for what it is
    Blossvale NY
    4,563
    Quote Originally Posted by rgthree View Post
    That's impressive considering the small margin of error that makes the difference between a transmission that works and one that doesn't! Well done!
    Personally, I would probably try and find the tranny parts on E-bay or here. But sometimes you gotta do what ya gotta do....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Feb 2012
    Alvin, Texas
    72
    Update: Turns out to be an 84. Working on posting a pic. I'm still new here, but i'll get it figured out.
    Thanks Guys!
    46
    Don't worry it went together more then once... Trial and error. An my thoughts were I'll buy a new gear this is just temporary to go riding this weekend. Lol
    Aug 2010
    Southern Oregon Coast
    932
    x3 on the $300 mark. Figure on doing a top end while you have it apart.
    Feb 2012
    Alvin, Texas
    72
    Decided to pass this one up. It was an 84 POS. I'll either put the $$ into my 250sx project or,knowing myself, find another one.
    1982 70-parts SOLD
    1979 110 SOLD
    1982 185s SOLD
    1984 200x Flat Track FOR SALE
    1984 200x SOLD
    1985 250sx FOR SOLD
    1985 250sx FOR SALE
    Jul 2011
    Lilly PA
    1,480
    I got a complete trany and counterbalancer for an 84 R that I cant use if you change your mind. $40+ shipping and its anyone that wants it.
    Just sit back and chillaxx
    Feb 2012
    Alvin, Texas
    72
    Thank's 84t3, I'll keep that in mind.
    1982 70-parts SOLD
    1979 110 SOLD
    1982 185s SOLD
    1984 200x SOLD
    1985 250sx FOR SOLD
    1985 250sx FOR SALE
