Results 1 to 3 of 3
Thread: Yamaha 225DX/200E engine oil leak question..
    Sarnia, Ontario, Canada
    3,415
    I am new to the Yamaha's, this is my second purchase and I am unfamiliar with there issues.
    So this is the second time I have seen a significant oil leak from the rear output seal on the back of the transmission, down the driveshaft tube and overfilled the differential with engine oil.
    Is this a common issue with the Yamahas? My brothers 250 Bear tracker has it slightly, now the 200E I just got had about 1/3 litre of oil in the differential. If poured out the fill plug when I removed it..
    How many others have seen this? What seal kit is needed to fix it?
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    The drive shaft is in 2 peices, the shaft comming from the engine then to the rear end with a coupleing gear. Its the seal leaking from the first part of the drive shaft where it is bolted on.
    I had one appart a few months ago, i put a 225dx engine in a ytm200e, i had to change the out put shaft on it, i had to install the 200e output onto the 225dx and thats when i noticed the big seal in there.
    3,415
    Is the seal replaceable as a kit??
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
