Results 1 to 7 of 7
Thread: atc90 w/ suspension fork swap, chopper?
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    Swapped on a 185/200 fork setup, still a work in progress. What tire combos are you guys running? This thing is a chopper with the 22 out front. Any advice is appreciated. Any tips for stretching the seat onto this thing? I have the rear seat pan hooked up, do I need to hook the front plates in first?
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    Jun 2009
    Leander TX
    2,217
    Put a pair of those same balloons on the rear like you have on the front.
    I believe I bolted on the rear mini pan first, then the fron plates. I do remember I had a heck of a time getting a useable set of those plates. They are not reproduced although ATC Heaven in Australia will make a set.
ID:	144330 Click image for larger version.
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    I kinda want the dirt tracker look, so I went with 18's out back.
    08 Yamaha WR250X
    My feedback:
    6,811
    I like this Kenda on the front when using 18" tires on the back .
    http://www.ebay.com/itm/Kenda-K284-F...item4cffb1c467
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    How wide is the rim its on. I think mine is 8x8.5
    08 Yamaha WR250X
    My feedback:
    6,811
    The rim in my pic is a 8X8 and its better to just use a tube to set the bead or lube one side of the rim up , set one bead and remove the tube and set the other side . I believe it only measured 19" tall after mounted
    Quote Originally Posted by tblumer View Post
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    The 22 I ethered on, the 18's had to be blown on with a cheetah tank.
    08 Yamaha WR250X
    My feedback:
