Thread: Tri Z Carb Issues - Stuck Slide?
    Feb 2012
    Hartford, WI
    76
    I thought I'd try to get my Tri Z "project" running, I knew that the throttle was stuck and thought/hoping that it may have been just a sticky cable.
    Pulling the air box off of it and finding the air filter made into one heck of a mouse nest....or I should really say "mouse condo complex!", I realized this wasn't going to be as simple as I had hoped......I unscrewed the slide from the top of the carb to pull the carb off and can't get the slide out of the carb. The carb looks as dirty as can be and the slide seems to be stuck inside the carb.
    Any tips for freeing it up? (I've been soaking it in PB Blaster) What else should I be looking for?
    '84 Yamaha 225DX Tri- Moto
    '85 Honda ATC 250R
    '85 Honda ATC 350X
    '99 Honda TRX 400EX
    Jan 2011
    Avon, Minnesota
    641
    soak it,,, i auctaly heated mine up once with a propane torch it loosens the varnish and also expands the outside of the carb a little since its hot usualy comes out
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Feb 2012
    Hartford, WI
    76
    Quote Originally Posted by yamaha driver View Post
    Thanks, I'll keep soaking it in PB Blaster unless you'd recommend something else to soak it in? I'm glad at least to realize I'm not the only one that has run into this!
    '85 Honda ATC 250R
    '85 Honda ATC 350X
    '99 Honda TRX 400EX
    Jan 2011
    Avon, Minnesota
    641
    see im cheap so i used wd 40 lol... im sure pb blaster will get it right out. it might take some tugging
