Results 1 to 3 of 3
Thread: honda atc 200m engine bolt #@%#ing wont come out >:(
    Feb 2012
    washington
    83
    just got a 200m and wanted to overhaul the motor and make it run better. went to pull it out and the lower rear bolt will not come out. the bolt head actually broke off. i tweaked the frame bracket and was able to pull the motor, but how do i get that @$#% bolt out. any ideas. thanx
    Apr 2010
    newfoundland canada
    7
    if all fails, try and drill it out, you can always re tap the hole. when i swapped motors in my 200m, the same bolt was a real b**** to get out, in the end, with a hole lotta heat
    and a grinder, it came out
    Feb 2012
    washington
    83
    i used the persuader (aka) biggest f#$%ing i had and walla thanx newfietriker
