Results 1 to 9 of 9
Thread: 250R FlyWheel Key Size
    AngusJustice is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canada
    219
    Question 250R FlyWheel Key Size
    Does anyone know the size of the flywheel key for my 1985 Honda ATC 250R? Mines sheared and I need a new one. Thanks.
    Jan 2011
    Avon, Minnesota
    641
    if you cant find one go to your nearest hardware store. they are 89 cents so just buy a bunch.... then grind them if needed
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Jun 2003
    englishtown NJ
    2,676
    go and get the right part from honda, its like $3. You want to mess with the timing of the motor and cause dentionation or pre-mature firing that will cost you alot more?
    Jan 2011
    Avon, Minnesota
    641
    alright???? i bought them for about 6 3 wheelers already..... STILL running to this day since they cannont be any different if they fit properly so its impossible to throw off timing. THINK about it
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    The 250R ones are an oddball size I've not been able to locate a replacement for. I've searched through mcMaster Carr and other industrial suppliers. OEM is the only ones I've been able to locate.
    NEPA
    7,051
    Quote Originally Posted by deathman53 View Post
    And stripped crankshafts and flywheels.... Buy the correct part and live happy.
    Jan 2011
    Avon, Minnesota
    641
    Quote Originally Posted by atc007 View Post
    then how come all these stupid oem woodruff keys are breaking??? and these woodruff keys are not....
    Jun 2003
    englishtown NJ
    2,676
    there is something that you are doing or an issue w/ your motor why they are breaking. My friend had them break a few times, flywheel wasn't put on tight enough. I put it on w/ air impact and it didn't break one for close to a year(sadly his bike was stolen not long after). Another issue can be main bearings that need to be replaced, vibration from the woobling crankshaft will vibrate the nut loose. Find the problem why its coming loose. A rare cause would be a worn taper in the flywheel or crankshaft.
    Ontario, Canada
    457
    I second death man, if it's not tight enough they shear. That's why there is a puller made to take it apart!!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
