Originally Posted by
Big Mike
While that is true for metric tire sizes ie. 235/75/16, it is not true in american sizes ie. 21x9x8.
In metric sizes it is 235 mm across the tread width, 75% of the width is sidewall height (75% of 235mm = 176.25 mm) and the rim size is 16
American is Diameter x Width x Rim Size so 21" in diameter, 9 inches in width, and an 8 inch rim size.
Like Ben said, if your tire is close to or the same width as your wheel, they suck to mount and get seated, thats why you should try to be at minimum 1" wider than your wheel width on your tire, and if you are too wide you run the risk of popping beads constantly too.
