Results 1 to 9 of 9
Thread: Any tricks to proper sticker/decal placement?
    Qdude79 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    CenCal
    369
    Got my '85 200X resto project fired for the first time last night (hallelujah!) and am starting to troubleshoot the minor things. With that, I want to finish it with the repro decals that it originally came with. Outside of putting it next to another 200X with original decals, are there any "tricks" that anyone uses to get these placed correctly?
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    You can mix a couple drops of Dawn dish washer detergent in a squirt bottle of water (like the size if a Windex bottle). Clean where the sticker goes, really well. Spray down the area with the soapy water, pull the backing from the sticker, spray it with soapy water and then place the sticker. The soapy gives you the ability to move the sticker around some. When you have the sticker where you want just squeegee the soapy water and any air bubbles from under the sticker and let it sit for awhile. You can also use a heat gun it help the stickers bend on curved surfaces, just heat and work it with a squeegee. A bondo paddle works well too.
    Jun 2003
    CenCal
    369
    Didn't know the soap trick, thanks! How do you know exactly where they originally went?
    Blossvale NY
    4,563
    Might want to look through some of the old brochures on this site for pics of your year/model trike....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Jun 2009
    Leander TX
    2,217
    I like the TLAR method for stickers - That Looks About Right ...
    Southern MN
    1,875
    I have seen a professional decal guy (he has his own buisness, and makes and sells decals) use windex. He sprays tank with a light mist, then the decal. He slides it to the correct positing, and uses a squeegee, then lets it sit for a while. Might be worth a try.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    dksix's Avatar
    Aug 2010
    610
    Are you sure it's Windex in the bottle? Windex has ammonia in it and ammonia degrades the adhesives most commonly used in this type of application. If you're going to use anything like window cleaner for something like this, at least use GlassPlus, it's ammonia free.
    Southern MN
    1,875
    Im sure I seen him use windex. At least, it was in a windex bottle, and it was a blue liquid.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Jun 2003
    CenCal
    369
    It's the placement I need help with. I don't want the tank decals, for example, to be rotated or too low...etc.
    I'm NOT good at TLAR!
