Results 1 to 15 of 16
Thread: 200x not starting
    Oswego, IL
    1,858
    200x not starting
    what might be the problem. my 85 200x isnt starting. and yes the kill switch is on.
    Sioux City, IA
    256
    Got fire, got compression, got fuel? Sorry for being broad, but there's nothing much to go by.
    "Trikes don't kill people. I kill people."
    www.250r.us
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    non-running 200x
    fisrt try pulling the plug to see if it is fouled. second- while the plug is out - check to see if there is any spark. If no spark then you may need to clean/replace the points. Could even be a dead cdi/coil.
    If you do have spark and the plug looks good, then you may need to clean your carburetor.. Sounds like it may be a dirty or clogged jet.
    Hope this helps..
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Oswego, IL
    1,858
    i got spark and fuel so it could be the carb. but it was running great and then all of a suddin i killed it and then it wouldnt start. thanks
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    is it out of time????
    Oswego, IL
    1,858
    how do i know if it is out of time?
    Oswego, IL
    1,858
    and is it hard to cheek if it is out of time?
    Rittman, Ohio
    6,276
    If it was running okay, and you shut it off, and now it wont start, its very unlikely its a timing problem. First thing to try is put a new plug in it.
    wizzard is offline At The Back Of The Pack Arm chair racerFirst time rider
    sometimes a plug looks good when you're checking for fire but just doesn't work. change the plug, it's only a buck or so
    '85 Tecate-project due....2029
    '85 350X
    Oswego, IL
    1,858
    i did before it stoped starting. it just semmes like it is somethin with the kick start. because it will almost start when pushing it. and it seems easier to kick. it grips a little it gets some compression. is there any way that the kickstarter shaft could be worn out?
    Oswego, IL
    1,858
    or could it be electrical?
    Oswego, IL
    1,858
    Jun 2002
    OH-IO
    816
    if someone forgot to put the bolt in the cdi, it could be a timing problem, or if it jumped a tooth or something....i doubt its electrical if it has spark. and the kickstarter isnt very likely to be the reason unless it is slipping.....if its catching it should turn over. could be a weak cdi, ignition coil. let me know
    Rittman, Ohio
    6,276
    Quote Originally Posted by vartiak15
    You can foul out a brand new plug in about 15 seconds under the right (wrong) conditions. Its your money, and you can replace things in whatever order you choose, but the plug is about $3 and if thats not the problem, youll just end up with a spare and be about $3 lighter.
    you might have sheared your flywheel key
    '85 350X
