Thread: Question about Yamaha clutch test??
    Sarnia, Ontario, Canada
    3,415
    I did say that I was a Yamaha newb and I would probably have more questions..well here is another.
    My 200e, along with it's serious engine knock slips in high gear and while climbing. Also my brothers 250 Bear Tracker is starting to do the same..
    With the Yamaha style 2 stage auto-clutch is there a method to determine which is causing a slip..meaning by drive-ability symptoms is it possible to determine if it's the centrifugal or the main clutch disks that are worn and causing slippage?
    Or do you just have to tear it down and inspect? The clutch set is cheap, but the centrifugal is not!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Howdy's Avatar
    Celina, Ohio
    10,079
    I'm pretty sure you can use the same basic test as Honda's. If it has to rev higher before take off, then the centrifical clutch is slipping. If it takes off fine in first gear but slips in higher gears then it's the secondary clutch. As with anything there are exceptions, but it is VERY rare.
    Howdy
    3,415
    Cool thanks Howdy!!
    Never had any clutch issues on my Hondas, but that is because they are Hondas..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Well ive had the clutch go in my Honda...
    If it's slipping in higher gear its time to change your clutch disks, its like day and night, mine would take off time, 1st threw 4th then start slipping with higher rpms... changed the disks and its like new.
