Thread: 110 nicholson
    Dec 2011
    Ontario, Canada
    509
    110 nicholson
    I like the looks of these nicholson frames but at $250 is that a good price? Also never built a nicholson before I assume that all or at least most of the stock 110 components bolt on to these am I correct in assuming that, and does this one look to be in good shape and not missing anything important? I'm sure with a good blasting and some powder it would look great and I have a guy with some nice fiberglass fenders
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    florida
    186
    looks like everything is there. 250 a little steep but there are not alot of them floating around these days
    Baltimore, MD
    6,088
    Firstly, let me start by saying, that's a great frame. Secondly, from an even greater seller that I would highly recommend. Now for the details. That is a chromoly frame that would have originally had a zinc anodized finished which would have resembled a matted gold color. Also, this frame is meant to take an atc70 tank. The chromoly is stronger and lighter than the DOM mild steel frames. These frames will take the late 90 and early 110 parts, so basically 76-81 parts. You will have to use the proper upper head mount, single bolt hole, so I think the early 110 mount, but either head mount is switchable. Generally these frames take points engines, but you can use the later cdi engines, but you have to find a place to mount your cdi. The holes are already drilled for the stock coil, which you should see 2 holes on the right side upper engine plate. Depending on what front end you use, you may have to fab some fork stops. This frame has the original finish under whatever that black stuff is. The price is very decent, as I was looking to add another nicholson "racing" frame to my stable. There is a stock Nicholson frame on ebay that takes the standard 90/110 tank and fenders and is made out of mild steel for more money. Also, it's a Nicholson frame. From the man that made some truly great hardware for many racers back in the day. Buy the frame so I won't. Please. And be very respectful to the seller, if you would. I can make you this promise, if you don't like the frame or seller, I'll buy it from you for what you have in it, cost + shipping. You can't lose. I will personally vouch for the seller as well, and several other members on here would personally vouch for the seller. You won't hardly find a better guy.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Lauderdale County, Alabama
    2,029
    One of Frank's sales? If so I totally agree with Veal on the seller recommendation.
    Baltimore, MD
    6,088
    No, not one of Franks.
    Nicholson 185s
    Apr 2006
    SE CA Dez in the sandbox
    900
    Well Vealmonkey, someone save you from yourself. That frame is gone. He's got another on egay though.
