Well we are about a month away and time to set some things in stone.
The ride will be on May 12th and pull out between 9:00 and 9:30 am. if you show earlier that is fine I would suggest it even. time for people to get to know each other and put faces with names.
Your atv must have a current Wisconsin trail pass.
Must have brakes.
Must be able to be riddin safely and mechanicly sound and not breaking down, ( everything breaks down once in a while i understand, just do not want some beater atv that should not be riddin out of your yard holding up an entire group) I know you all understand.
MUST wear a helmet!!
for this ride you do not need the liscence plate yet, ( that law starts July 1st) I may have them on mine by then and would suggest you do the same, one less reason to get pulled over and inspected. The plate has to be minimum 4 inchs by 7 1/2 inchs. It needs to be white with black letters and mounted on the back of the atv, yea I know good luck mounting them were they won't get destroyed or block the taillight. these plates are your responsability to have and make, the dnr does not supply them.
As of right now a cook out is not planned, there are to many people saying they are going, to have my wife cook for all of us. There is a great little restrant/bar across the field from me. We can eat lunch there. This may change, if people want a cookout and bring some food and charcoal it can happen, I have a few grills to use. If we do eat and do lunch at my house depending on the # of people I can get a porta potty also.
I have a large driveway and yard so parking with a truck and trailor is easy, I am also only 3/4 a mile off of state hwy 32 north of Suring WI. If you need directions just pm or email me. Very easy to find, about 45 min. from Green bay, 1 hour from Appleton, just over an hour from Iron Mountain MI, 45 min. from Marinette WI and a little less than an hour from Antgo. 2 hours from Wausau.
If you are a for sure just say so in this post and we will see you on the 12th.
It is a great time with fellow riders and a great start to the riding season. Hope to see you then..
