Results 1 to 12 of 12
Thread: 250R 85/87 Swingarm bushings White
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Post 250R 85/87 Swingarm bushings White
    White swingarm bushings for 85 to 87 atc and trx. Time and race proven. If you can wear a set of these out I will replace them. These are reusable if you change swingarms.
    Price includes priority shipping in the US.
    Can ship global priority if needed.
    More...
    Carthage NY 250r rules
    2,355
    Are these available for the 83-84 250r.I have a set that was made by someone else.Havent used them yet but I hear great things about them.
    Michigan
    1,220
    Quote Originally Posted by atc300r View Post
    Yes they are, they will be in the store Monday in black or white.
    2,355
    Thank You Bill and X.system. A lot of guys have been looking for the 83-84 style on other sites.
    Dec 2011
    lake charles la
    9
    did they all sell out for the 83-84 models
    Michigan
    1,220
    Quote Originally Posted by bryan70546 View Post
    I havn't got my material for that model yet, I ordered it last week but that size wasn't in stock aparantly. I expect it here yet this week.
    Aug 2011
    Sacramento
    41
    Bought these for my '85. What are the installation recommendations? How tight do you tighten the bolt to. I'm not getting response anywhere else so I thought I'd try here.
    Thanks
    Michigan
    1,220
    Quote Originally Posted by Helidaddy View Post
    Thanks
    Take out all your oem parts and tap the bushings in, pretty simple. Do not tighten to oem specs, I tighten the nut until there is no play side to side in the frame. Use the original nylock nut or a new nylock nut and I always use blue locktite on the nut. Doesn't hurt to add some marine grade grease when you first install. My phone number is listed in the 3WW store, feel free to call with any questions any time.
    Maryland
    3,077
    x.system, as i understand it you make these to do away with all the oem parts, can you make sets that still use the inner bushings on request? I.E., the metal bushings that the swing are bolt fits in, effectively your bushing will replace the dust caps, and bearing only.
    Michigan
    1,220
    Quote Originally Posted by Louis Mielke View Post
    On the 85/87R I can, I do the Tiger bushings that way so it shouldn't be a problem.
    Aug 2011
    Sacramento
    41
    Quote Originally Posted by x.system View Post
    Thanks X! Exactly what I needed to know...
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    Have you gotten the 84 250r plastic swingarm bushings yet? I need a set bad.
