This is my 2000 Blaster that I had @ TF03(used to be blue/blk).It's almost ready for flat track racing.I got my new 30mm flatside carb today.LRD pipe will be here by the end of the week.Still looking for front tires,steel nerfbars,and some numberplates. I also used a tri-z axle and rear disc.the Z axle is about 4 inches wider than stock.Rear tires are 18x9.50x8 carlisles,purchased at walmart. The paint is isuzu claret red metallic.The struts were made by Crazy G Racing (Thanx Hagen) .The struts fit perfect,I only needed to add spacers in the rear on the bottom.
I doubt it will make it up devils backbone.When I roll it out of the garage it clears the edge of the concrete by 1/2 an inch.It will take some time getting used to riding a rigid quad 3 inches off the ground.
