Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: just bought myself a trizee 250......
    May 2003
    Houston, Texas
    2,409
    No thats a 1986 Model for sure!!!
    White fenders and red plastic definitely an 86! It would be nice to see you stick with red and white color scheme.
    Looks like a fun project!
    Darius
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    denn is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Lehighton PA
    213
    If you want to know for sure check the frame #'s on the steering head. Anything 86 will have 1RX as the first three. 85'S have 38W. This includes your shock reservoir, engine and some other misc parts. It good to know this way you can see what was mismatched with 85. But I can tell you that is an 86 frame you have. Good luck with it.
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    what is different from the frames that you can tell?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    1rx it is...................86 THEN...........
    Dec 2002
    749
    If I was you I would get the frame and all the old red steel parts powdercoated red again and then go with 85 Yellow Z fenders and shrouds. It'd look sweet IMO.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    ewwwwwww red and yellow......nahhhhhhh......remind me not to ask for your help redecorating my house.hehehe .....looks ominous for the engine stripped it today and descovered 2 1 1/2" scores on the front side of the piston and the matching scores below the exhaust port.....and a very small amout of play in the main bearing.....rebuild time,,,,, 8)
    May 2003
    Houston, Texas
    2,409
    Can you snap some pics of the those piston 'scores' on the front of your piston.
    I saw that on my 'Z' when I removed the exhast pipe. Are any scores bad to have on the piston...I tend to think it means the rings are well worn.
    Darius
    Otherwise how deep are they, etc?
    Dirtbikes:
    1988 Yamaha DT
    not a very good pic but you can see the score marks......and a pic of the engine as it was removed from the frame
    REAR AXLE ARRIVES FROM IRELAND......CANT WAIT TO GET THE FRAME AND SWINGER BACK FROM THE POWDERCOATERS......ANY ONE GOT ANY CLOSE UP PICS OF HOW THE AXLE FITS TO THE SWINGARM......AND HAS ANYONE GOT THE APPROPRIATE BRACKETERY TO FIT THE AXLE TO THE SWINGARM....... :shock: :shock: :shock:
    May 2003
    Houston, Texas
    2,409
    Thanks for the pic...mine are worse than that...probably should be changed now!
    Thanks and I can't wait to see more pics!
    Darius
    Dirtbikes:
    1988 Yamaha DT
    Ashland City, TN
    2,576
    Is that a flat top piston dude? Where did you get a flat top piston? Doesn't look domed.....maybe it's just me?
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    it's not flat flat.......it's a little domed....dude...
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    yep, those marks mean bad rings, the black streaks are where the oil/gas has been blowing past them....if you have them its definatly time for a rebuild, or at least hone the cylinder and get new rings
    Good Luck with that.
  15. #30
    rebuilt the rear shocker and painted it also replaced the front fork seals and painted the bottoms........lookin good.......
