Results 1 to 15 of 21
Thread: Smokey crankcase ?!!?
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Well, iv noticed recently that on my 200s theres clear smoke comming from the crank case and when i check my oil after maybe 2 mins of warm up theres steam comming from the dip stick hole !, What causes this? Ive done some searching and seems to me it leads to RINGS,, well it cant be that..not yet anyways, top end was redone 4 months ago and doesnt smoke threw the exhaust..... When its warm its blue smoke threw crank breather.
    Last week or so i did blow a head gasket, ive replaced it and it quit smokeing threw the breather but now its doing it AGAIN !
    NEPA
    7,051
    Wasn't it you that had a blown head gasket/ other troubles w a fresh Wiseco a cpl weeks back? You need rings. If it was you,I posted that then. Whatever,and why ever,you need a fresh seal again in your cylinder. Sorry to be the bearer of bad news.. Only one way combustion can get down in your crankcase.
    Nov 2010
    446
    Yeah it was me AGAIN !! I blew the gasket again yesterday i have no idea why, its been such a dream all winter long now its just being a pile...
    The gasket blew on the same side and head nut came off again, the engine stud itself is black and the dowel pin was melted aswell just like last time ! The left hand side at the back of the head.
    I did notice before there was pressure comming from the breather and little oil was comming out but not lots, now its blue smoke and oil EVERYWHERE from the crank... could the rings have been installed upside down? Cousin put them on the piston for me one night then i installed everything the next day..
    Jan 2011
    Avon, Minnesota
    641
    it sounds like your head is warped.... or cylinder surfaces are fked up. if its doing it in the same spot multiple times thats your reason for blowing gaskets
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Nov 2010
    Oshawa, On, Canada
    2,123
    Did you use a CHEAP head gasket? Anything but Honda OEM SUCKS!
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Nov 2010
    446
    I have no idea, its always the metal ring that melts to the dowel pin and then to the stud !
    Well talking about cheap gaskets, wanna know something funny?? When i did my rebuild, the lad got gaskets for me, there made by Winderosa.. i put them in and for the first couple rides the base gasket would seap oil all the time, the more i drove it the less it would leak and finally stopped leaking, then the cylinder head gasket started to get wet then all of a sudden pooff DESTROYED.
    So im guessing Winderosa gaskets are junk? What should i do then, order a different brand or OEM?
    I was always thinking such its a .20 200x wiseco, its too much compression for my 200s engine or just gaskets are junk....?
    Nov 2010
    Oshawa, On, Canada
    2,123
    I would check over gasket mating surfaces for any burs, or any warpage.
    Measure your ring gap, inspect cylinder, and if all is well, order some new dowel pins, and OEM gaskets for the whole thing.
    I have several friends who decided to go cheap, and they let go within a month.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    what oil are you running
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
    NEPA
    7,051
    Again,you need a NEW stud and nut. Check your head and cylinder for warpage. New Honda gasket. Pull your cylinder,measure,start from scratch. Yes,rings can be put on upside down. The markings always go up.Start at the cases and build her up right! Again,,the bearer of bad news.. But you've gotta get the loosening nut problem addressed.
    Something is wrong or can't hold the torque speq and or you have a warped head which you would know if it's been yours for awhile.
    They have to get pretty hot to warp. Or a prior by mechanic......
    Then again this is why they say "loosen bolt A, then B, then C, then D. You can warp then merely by dis-assembly........ Always crisscross slowly;Never just zing them out one at a time.
    Nov 2010
    446
    I wasnt going to put this but, the first time i blew the head gasket was my mistake intirely, i had pulled the engine out to shine it up real good to get the grease off the engine. When doing so, i pulled the head pipe off, cleaned the engine all up with citrus degreaser then reinstalled. Im guessing when i mated the header to the muffler, i pushed the asbestos gasket back into the muffler making it loose and when i went for a ride later on, it had fallen completly into the muffler PLUGGING it solid And thats when it blew.
    I got it towed home, pulled the engine changed the gasket and checked it all over... when i installed the header back on i didnt see the muffler gasket anymore ! So that was my first clue...
    I pulled the muffler off and sure enough it was packed solid ! I took a drill with a long drill bit to clean it all out, ive got it all im sure i couldnt see anymore but i could be mistaken because it happened again!!!! My fault entirely...
    EDIT: im running 10w40 kendall, and for rings upside down... i remembered that this wiseco 200x piston didnt have any markings on the rings..
    NEPA
    7,051
    Every Wiseco,or any ring for that matter HAS a stamped mark on the end of the ring on ONE side. Anyhow,you know what you need to do now : ) Pull her apart and spec everything,,if you end up needing a used head,,I think one will be cheap. Good luck!
    Nov 2010
    446
    Ive only got about 3 of them laying around lol, thanks for the help!
    Nov 2010
    446
    Well i tore into the trike about a half hour ago and its terrible... the rings are non-existant and theres a large chunk taken out of the piston side where i kept blowing the head gasket, lots of carnage...
    Time for another rebuild UUUGGGGHHHH
    Jan 2011
    Avon, Minnesota
    641
    have any pics?? sounds like it was installed wrong causeing that damage
