I want to remove the chain guard off my 81 185s so I can paint the frame, how do I go it? Or how do I remove the rear sprocket? There's those four bolts but they just spin. What do I do??
1981 Honda 185s
1984 Honda 200x
1984 Honda 185s
there should be 5 bolts that you have to remove. there is a cover with three bolts on the axle, they needs to come off and there are 2 on the case itself in the middle. you probably need to hold the other side of the bolts so that they don't spin. at least, that is what its like on my '83 185s
Gone:
I can seem to get to the other side of the bolts, they're somewhere behind the sprocket, I can't get the two bolt behind the sprocket mounting the case to the frame
1981 Honda 185s
1984 Honda 200x
1984 Honda 185s
Before you do anything, either purchase a honda shop manual for your year 185s or download a shop manual off the internet and do so reading. If you would have done either of these, you would not be asking these questions. Not saying the questions are bad, but you need the proper knowledge that a shop manual provides. Also you need a nice set of basic tools, but proper torques wrenches are a must.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
if you try tightening the sprocket when its on the machine it is a hard time... i do it on my dads big red but it takes friggin for ever. you have to pull the axle to do it right.
1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
1982 honda 200 bigred cobra exhaust
1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
I have the Clymer's One and it works for bth my 200x and 185s, ehich was cool. But I couldn't find it, I'll take a look again I might have missed it. And I've got a buncha tools for school (I'm training to be as they call it an "automotive technician" aka mechanic) so I've got everything to do it and In order to remove the axle I'd have to remove the guard.
1981 Honda 185s
1984 Honda 200x
1984 Honda 185s
the outside gaurd comes right off.... all you have to do is just remove all the bolts holding it you see. the inside cover stays on
I'm tryin to remove the inside one, the outside one was easy, but it's rubbing the inside one and I wanna either remove the dent or just completely remove it all together
1981 Honda 185s
1984 Honda 200x
1984 Honda 185s
to do that you have to remove the sprocket which intern leads to removing the axle
It's a vicious cycle haha
1981 Honda 185s
1984 Honda 200x
1984 Honda 185s
