Results 1 to 15 of 20
Thread: 250r street legal?
    gus's Avatar
    gus is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2011
    tucson arizona
    453
    250r street legal?
    How can you make an 86 250r street legal in the state of az? its legal to drive 3 wheeled atvs on highways and public streets as long as you have the following 1. Turn signals 2 mirros and 3 a horn and you must take a mortocycle class (figures right) but quads don't anyways question is Would the stator be able to handle it the horn and turn signal?. Is there a kit? Or i 'em suppose to make it peace by peace Any help would be appreciated
    Big Mike's Avatar
    Hanson, MA
    1,062
    I suppose the stator could handle the extra load of turn signals and horn as long as you use LED directionals. Maybe you could make something like this work on the 250R http://www.ebay.com/itm/Baja-Designs...item4164a64f68 Just change the bulbs out to LEDs.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    gus's Avatar
    Jul 2011
    tucson arizona
    453
    I've seen that kit on rockymountainatvmc.com for about 200 bucks less but would it be better just to replace all bulbs instead on the hole front light assembly?
    You're probably going to end up having to install a battery. At that point it won't really matter if you use LED's or not I'm guessing.
    Sarnia, Ontario, Canada
    3,415
    If you are gonna put that much load on your electrical you really should install a battery/voltage regulator...
    Like Fabio said..great minds!!!
    Also, make sure every spec of paperwork is in order and ready to produce..I say you'll have flashing lights in your little tiny rear-views on a daily basis!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Oct 2006
    2,504
    Quote Originally Posted by dougspcs View Post
    Feel free to read this PDF file at your leisure.
    http://www.azgfd.gov/pdfs/outdoor_re...v_brochure.pdf
    Couple quick notes from the PDF file.
    Equipment you need to
    operate your OHV in Arizona:
    ◆◆ Helmet that is properly fitted, fastened and has
    a USDOT safety rating for those under 18 who
    ride on an OHV. Riders in an OHV such as an
    ROV do not need helmets; however, it is recommended
    that all OHV users wear a helmet.
    (ARS § 28-1179B)
    ◆◆ Spark arrestor that is USDA approved.
    (ARS § 28-1179A.4)
    ◆◆ Brakes adequate to stop and hold the
    vehicle. (ARS § 28-1179A.1)
    ◆◆ Muffler or noise dissipative device that prevents
    sound above 96 decibels during prescribed
    stationary sound testing. (ARS § 28-1179A.3)
    ◆◆ Eye protection for operators of vehicles not
    equipped with a windshield. (ARS § 28-964A)
    ◆◆ Headlights and taillights for use from dusk to
    dawn. (ARS § 28-1179A.2)
    ◆◆ Safety flag at least 6” by 12” and 8 feet above the
    ground on sand dunes or areas designated by the
    land management agency. (ARS § 28-1179A.5)
    ◆◆ Brake light and at least one red rear reflector
    (if taillight does not reflect). (ARS § 28-927)
    ◆◆ License plate securely fastened to the rear of the
    OHV and clearly visible. (ARS § 28-2512D.1&2)
    ◆◆ Rearview mirror. (ARS § 28-964B)
    ◆◆ Seat and footrests for the operator and passenger
    if vehicle is designed to carry a passenger.
    (ARS § 28-964B)
    To make your OHV street legal
    you will also need:
    ◆◆ License plate light. (ARS § 28-925C)
    ◆◆ Horn audible from a distance of
    at least 200 feet. (ARS § 28-954A)
    ◆◆ Proper insurance. (ARS § 28-4142A)
    ◆◆ Emissions: Certain areas may also
    require you to have your OHV emissions
    tested. (ARS § 49-542C&D)
    Title-Only License Plate: The title-only license
    plate is currently identified by the letters “RV”
    displayed on it. This is an identification plate
    and does not allow travel on roads that require
    “street-legal” registration. (For exceptions see
    www.azgfd.gov/ohv.)
    Registration License Plate: The registration
    license plate is currently identified by the letters
    “MC” displayed on it. This “street legal” plate
    does allow travel on roads, trails and areas on
    which registration is required. It is your responsibility
    to ensure that your vehicle meets the necessary
    “street legal” requirements.
    gus's Avatar
    Jul 2011
    tucson arizona
    453
    Ya no kidding dam police lol really a battery? So going led wouldn't matter how much would those extra lighting put out? I think the stock oem stator dishes out 100 watts or so? Maybe 150. Have any of you guys herd of a battery eliminator kit?
    Ontario, Canada
    457
    What about the 200w stators? Signal light is only what, 5w maybe 12w? No idea what a horn is...
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Nov 2004
    Waterloo IL
    2,701
    Most states don't require turn signals. Arizona is one that does not require them, and it says one mirror. http://www.bikerplaza.com/motorcycle-law.html Really all you need to add (in my opinion) is a stop light. Run a TRX450R tail light, they are LED.
    But I don't think you will get it street legal. I've always heard you cant run a locked rear axle on the street.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    gus's Avatar
    Jul 2011
    tucson arizona
    453
    I could sworn I read that you need turn signals? Idk I might have read wrong. Ill be going down there soon to get the title transfer to my name so ill ask what's the requirements for how to make a atv street legal
    Oct 2006
    2,504
    Quote Originally Posted by Blown 331 View Post
    Why not? Where in the list of things I linked that is published by the state of Arizona does it talk about the axle. I see quads all the time on the streets of Arizona.
    gus's Avatar
    Jul 2011
    tucson arizona
    453
    I saw a quad the other day he flew right pass me
    Nov 2004
    Waterloo IL
    2,701
    I see quads on the street all the time too, they just aren't legal. No on here is an authority on this matter, just stating my opinion.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Oct 2006
    2,504
    I understand you see them on the road illegally in Illinois, what I am telling you is FACT in Arizona. Arizona allows for street legal ORV's, I have posted factual information and links and you choose not to read up, fair enough.
    I may not be the "authority" but I have done my research and homework, and every time I go get a title for my ATC's they ask "do I want to make it street legal?"
    More information From this link:
    http://www.ledtsk.com/AZOHVLawsRulesandRegs.pdf
    "If the driver of an off-road vehicle intends to drive
    on Arizona streets or highways, the vehicle must be
    properly registered. An ATV must be street legal
    before registration can be issued; some ATVs may
    require additional equipment or modifications in
    order to meet this requirement. To obtain registration,
    you must visit an MVD office; you are not required
    to bring the vehicle in to obtain registration."
    Equipment needed
    for registration
    • At least one brake that can be operated by hand
    or foot.
    • Brake light.
    • At least one, but not more than two, headlights
    that shine at least 500 feet ahead.
    • At least one taillight visible for at least 500 feet
    to the rear.
    • At least one red rear reflector, if not part of
    the taillight.
    • License plate securely fastened to the rear of
    the ATV.
    •License plate light.
    • Horn audible from a distance of at least 200 feet.
    • Muffler in good working order and in constant
    operation. Muffler cutout, bypass or similar
    device prohibited.
    • Rearview mirror.
    • Seat and footrests for the operator.
    • Fuel tank cap.
    • If you live in the Phoenix or Tucson metro
    areas you may also need to have your ATV
    emissions tested.
    There are two plates you get for an ORV. One is the R/V and one is the M/C. The RV is strictly off road, the M/C may be street legal if you have the above list of requirements. Emissions testing and insurance to me is the biggest hurdle, not the axle, not street legal tires etc etc......Many of the riding areas in Arizona are fire roads or "maintained" roads and require the M/C plate to ride, which means they have to be "street legal", not just for off road use (RV plate).
    Nov 2004
    Waterloo IL
    2,701
    I stand corrected on my locked rear axle statement in the state of AZ.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
