Thread: Honda 185 ignition problem, help
    Nov 2011
    Connecticut, USA
    50
    Just put a 185 engine on my 200e frame, as my 200e motor is currently being torn down for a blown 2nd gear. Bolted it on, the engine had no spark. My friend who I bought it from gave me a new pulse coil with it. I pulled the flywheel off, and saw that the existing pulse coil had been sodered to the ground instead of the tab in the middle of the pulse coil. I replaced the pulse coil with the new one and sodered it to the correct tab. Put everything back together, give it a quick pull with the plug against the block, got a nice bright blue spark. Put gas tank back on, hooked up line, gave it a couple pulls and it fired right up running real nice. While picking up tools letting it idle for about five minutes or so, it suddenly shut off. Give it a couple pulls, nothing. Take the plug out and give it a couple pulls, no spark again. Ideas folks?
    1981 Honda 185s
    1982 Honda 110 (junker under a tarp for now)
    1983 Honda BIGRED-185s Hybrid
    1985 Honda BIGRED 250ES
    1985 Honda 250sx
    1983 Kawasaki KLT250a
    Mar 2012
    Jamesport
    40
    something must've shorted out, maybe the soldered wire from the coil or perhaps the coil burnt out, it makes since to start with what was replaced.
    1970 ATC US90
    1984 ATC 200X
    1985 ATC Big Red 250ES
    1985 ATC 70 x2
    1984 YTM 225DX
    1985 KLT 185
    2007 CRF 450R
    1995 Kawasaki Bayou 300 4x4
    Nov 2011
    Connecticut, USA
    50
    Just tested the pulse stator that I put in last night, only testing at 220 ohms, 265 required. I have another pulse stator that is testing at 270, about to solder that in now. If it shorts out again what issues am I missing here?
    1981 Honda 185s
    1985 Honda 250sx
    Nov 2011
    Connecticut, USA
    50
    Crap. Done for the night. Put in a new stator, put flywheel back in place and attempted to tighten it back down.... Having removed it a couple times in the past two days stretched the threads and the nut f'd up the first two threads on the crankshaft. Guess I will have to recut the threads with a die tomorrow and hope for the best. Anyone ever done this before?
    1981 Honda 185s
    1985 Honda 250sx
    Mar 2012
    scotland
    29
    i mushroomed the threads on the end of the crank trying to pull the flywheel off.once i got it off i split the thread die in to two halves (i did it accidently and the old boy wasnt to chuffed) so i place the two halves on the threads and held them together with a jubilee clip and cut the threads in reverse.it seemed to do the job fine.
