Results 1 to 15 of 19
Thread: Rear sprocket removal - help
    Apr 2012
    MS
    31
    I can not figure out how to get this damn thing off. The bigger bolts just spin and I can't get a end wrench behind it. The cover will not come off without the sprocket being off. The manual does not show anything. What is the obvious solution I don't see?
    Dec 2011
    Ontario, Canada
    509
    What year and model is it? and those teeth on the sproket all look bent to the side are you replacing it?
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    6,815
    Remove the axle and then all the bolts on the sprocket . The large bolts hold the sprocket to the axle and the smaller 6mm bolts hold the rubber dampener plate to the sprocket .
    Apr 2012
    MS
    31
    It's a 1984 ATC 200M. I bought a front and rear sprocket set and the new rear sprocket does not match. Wtf
    Dec 2011
    Ontario, Canada
    509
    doesn't match the one thats on there now? teeth wise? it might just not be stock size but the set would still work, might have to take a few links off your chain though
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Apr 2012
    MS
    31
    No the holes don't line up (pics below). The manual shows four holes and the one on there has five. Guess someone change axle (I guess). Maybe not, thoughts?
    Dec 2011
    Ontario, Canada
    509
    Iif the 200m didn't have the chain cover on it i'd run out real quick and check mine and the kids wouldn't know I left lol someone will let you know whats up soon on here there alot of knowledgable guys here, good luck
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Jun 2009
    Leander TX
    2,217
    Looks like the totally wrong sprocket to me.
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    my 84 aint even close to that just had it off today
    1984 Honda 200M
    1984 Honda 200M
    1996 Yamaha 250 Timberwolf 4x4
    1990+ Xingfu Hunter
    1986 Suzuki SP200
    Apr 2012
    MS
    31
    Yeah I think it has been changed out. After looking around it looks like a 1982 200 sprocket. I guess I'll buy one and try it
    out.
    Howdy's Avatar
    Celina, Ohio
    10,079
    That looks more like a older 185-200 axle to me. I used to have a New sprocket for them at the shop. Now I am wondering if it is still hanging on the wall.
    Howdy
    Apr 2012
    MS
    31
    Edited to add pic
    Apr 2012
    MS
    31
    Ok I finally got the right sprocket. I will have some free time this weekend to attempt to remove the axle. I have read some reviews on this site and watched a couple videos. I have remove the tires and chain and plan on removing the pieces indicated in the pics. Any pointers on how to remove for someone that has never attempted?
    6,815
    You dont have to remove the bearing carrier to do the job . Also while your in their you should replace the axle bearings and brake shoes . The brake drums are famous for being hard to remove so a little heat and a big is your friend !!!!!
    Apr 2012
    MS
    31
    Ok thanks. Glad I asked. I do not have anything to heat with so I guess the will have to work. Are the bearings on eBay ok or should I use something else? Thanks.
