Results 1 to 7 of 7
Thread: Yamaha 225 cylinder?? Aftermarket available? Thoughts?
    Apr 2012
    Wisconsin
    3
    Doing a 225dx motor build. Does anyone make an aftermarket 225dx cylidner? Or is new/used yamaha OEM the only option? Looking to go bigger with a new piston, wondering what others have done and how it worked out, good, bad, etc. Suggestions, ideas, etc. Thanks for the input.
    louisiana
    1,499
    There is some new aftermarket cylinders on eBay that are std bore.if your looking to go bigger you can use a timberwolf or bear tracker cylinder but there isn't a high compression piston for those bikes.
    Signature pic removed,becuase of no helmet.
    Apr 2012
    Wisconsin
    3
    Ive done some reading around and just want to be sure im understanding correctly, Am I able to take the stock timberwolf/beartracker cylinder and a wiseco 71mm piston and they will go together without needing any boring or machining. It will give a touch more cc and give me the higher compression that I need?
    thanks for your input
    Pekin IL
    529
    Someone told me that you had to bore the dx case to fit the timberwolf cylinder but i dont know that for sure
    glendive, montana
    1,822
    you do have to bore the case and it is not a higher comp piston it is lower, so it's not worth it. There are plenty of aftermarket pistons out there none of which that I have seen are hjigh comp, but when the dx can do 50 mph with a stock bore and piston what more can you need. There is no way to make these compete with 2 stroke but my dx is able to keep up with a 660 grizzly so why and try to supe it up more. If you need to replace piston and rings and have the cylinder bored, than do that. These are a shaft driven trike.
    Pekin IL
    529
    My buddy runs a wiseco in one if his and i thought it was a hc piston. Also eather web or mega lists a cam for the 225.
    Dec 2011
    oswego, new york
    ive got a dx thats 40 over with web cam and bigger main jet. top end wise im doing around 60-63but the increase in torque is the best part. this thing will stand straight up in every gear with little to no effort. thtas just my imput
