Ok, I took the rims apart to put some new tires on, I thought that maybe (for some crazy reason) that the rims were made to seal, but that wasn't the case.
So I went to autozone and got some High heat, torque and etc.. RTV and put a bead around the outside lip, inside lip and around each bolt hole. I just snugged the 4 bolts down
and then after an hour cranked on them tight.
Do you think the RTV will seal good enough?
I made sure to wire wheel the surface and wipe it down really good.
If it doesn't work should I just trash em and get some solid rims?
I looked on some blown out schematics and nothing was even shown or mentions about the rim coming apart...
Thanks.
