Results 1 to 15 of 18
Thread: home made dump trailer now how tomake it dump? any ideas?
    Mar 2005
    overton, PA
    5,257
    ok i made a small dump trailer and the frame is made i plan on having a 4 1/2 foot by 48 inch dump bed on it, its all 2 inch square tubing and build to hold up, but what types of lifts can i use any ideas to get it to lift?
    May 2007
    Orange County, NY !
    1,672
    Boat winch? Make the pivot just a little to the rear of the center, so not much load will be put on the winch. Run the cable under the trailer from the front to a leverage point in the rear. You may to run the cable over a pulley that extends down to give you leverage.
    OR get a hydrolic set up.
    Mar 2005
    overton, PA
    5,257
    i am leaning more torwards a hydrolic set up something like a scissor lift with a long travel 3 ton ran laid down on the tounge but dont know how to make it work and as far as the pivot point i haveit set up so its balanced and ablout a foot from the back for optimal ground clearance while dumping.
    May 2007
    Orange County, NY !
    1,672
    Just look at how a dump truck uses a ram, you don't need a scissor lift. Get a harbor freight 7 ton electric log splitter, and use that. Or piece something together from northern tool. HEre are some blue prints:
    http://www.northerntool.com/shop/too...1179_200331179
    Sep 2011
    oswego ny
    70
    out of the stuff you got take a 2 stroke and hook it to a hydro pump then put your ram in send me pics of the frame brapp ill get some plans drawn up and send em back just make sure your trailer tires are s
    Last edited by bigbore88; 04-26-2012 at 10:00 AM. Reason: im and idiot and cant spell
    1984 ATC 200X Project Running and riding
    1985 ATC 200x Project in pieces
    SUPERZINGER
    Mar 2005
    overton, PA
    5,257
    i have a big bri mar dump traile rbut its too big for the quad and tractor, i am tryign to figure a way tyo carry a 1/2 ton or so of food or dirt stone etc and be able to dump it without alot of hydrolic components or ton of weight, i was thinkign a sliding block around the tounge and a pivot and bar upright and a long ram (like off a engine hoist)
    Big Mike's Avatar
    Hanson, MA
    1,062
    What about building a small frame that extends up from the front of the dump portion and using an engine hoist ram? Make the frame tall enough that the engine hoist ram will fit in their fully closed and you should be good. it will be manual but could work, just make sure the ram can pivot at the top and bottom.
    Similar design to this:
    I used to build truck bodies and this is how we built almost all of them, because it just needs a pivot at the very back of the body and the piston at the front does all the work. It is so much fun changing out pistons of this style body, because they weigh like a 1000 pounds and you have to lift them straight up and out. My father and I have been doing them since I was like 15 yrs old together at one of this fleets he takes care of.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    A single stage piston isn't going to give enough height.
    Big Mike's Avatar
    Hanson, MA
    1,062
    Well it depends on how high he really needs to go, a 4.5 foot trailer with the hoist piston should be enough height?
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    1980 ATC 185S
    Mexico
    9,014
    Isn't that what reverse and brakes are for?
    Quote Originally Posted by Big Mike View Post
    Oh yeah, I didn't realize it was that small.
    Big Mike's Avatar
    Hanson, MA
    1,062
    Way to pay attention to the details. HAHA!!!
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    1980 ATC 185S
    Mar 2005
    overton, PA
    5,257
    i think i have it figured out i am gonan do a slidign block and a 3 ton ram with 16 inches of travel lay it down along the tounge and have a slider block around the tounge with a 14 inch arm that lays down so as it slides the block back the arm that is attached to the body raises the bed?? possibly a good plan?
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    That looks like a bibeau body on that tandem?? Maybe I'm wrong. Looks the same as whats on our Volvo Tandem at my job.The cylinder looks the same as well.Your not kidding about them being heavy.
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by brapp View Post
    glad you have it sorted(mostly) when your done figuring it out you can figure out a chain tensioner for my T2 lol. If my funds permit I wanna get down there in a couple weeks I could give you a hand if needed
