Originally Posted by
RIDE-RED 250r
Well, Wiseco's recommended service life on their pistons is just 40 hours if I remember correctly. Basically, 3 heat cycles which is start it up and bring it up to operating temp with no load. Meaning do like you would do to get it warmed up before riding. Once up to temp, shut it down and let it cool completely.
After 3 heat cycles, now ride it, varying the throttle, rolling into the throttle up to 1/4 throttle. Do this for about 10 or 15 minutes. Shut it down and let it cool completely. This is a good time to check for leaks and any other issues.
Once cooled completely, fire it up and do the same. Only now roll into the throttle up to 1/2 throttle. Again, do this for about 10 or 15 minutes then shut it down and let it cool.
Once cool repeat this procedure rolling it up to 3/4 throttle. By this time you will have probably burned about 1/2 tank of fuel or so.
At this point after the previous run cycle you can pretty much ride it as you normally would. Just avoid prolonged steady RPM's and keep varying the throttle till you get about 1 full tank of fuel run through it.
After that, done.
Yeah, on a wing-dinger, 150 engine hours is a looong time to be the point it's considered broke in! You would likely be due for a fresh top end long before hitting that 150 engine hour mark..
