Originally Posted by
RIDE-RED 250r
That stinks. Gotta have the right key in there or the flywheel will not seat on the tapered crankshaft properly and loosen up. The flywheel is mainly secured by the tapered shaft fit. The key is really only there for proper flywheel position on the crank for correct ignition timing. The key isn't bearing much of the load of the flywheel.
That's why I was puzzled on the situation. Two more ordered yesterday.
Would a video help at all?
Through the throttle range, there is basically no "non-powerband" in that it takes off and doesnt slow down all through the throttle range. It isnot fouling plugs, though it is running a bit rich. Is this abnormal, or do I have a well build engine? I have a video here: http://www.yourfilelink.com/get.php?fid=800830 You will have to download it, I promise it is safe.
Also, I was unable to replicate the WOT bogging issue. I seem to remember using a lot of oil that made it's way into the crankcase during the rebuild so i suspect it has been working itself out.
1984 ATC250R #1
Maxxi crank and transmission bearings
Wiseco piston
bored 6 times out
DG type 2 exhaust
power reeds
K&N air filter
mongoose stator
1984 ATC250R #2
Boss crank and transmission bearings
Wiseco piston
bored 7 times out
hollowed out factory expansion chamber
