Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
Thread: Tri-z mod jetting issue
  1. #31
    tippmann's Avatar
    tippmann is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    canada quebec Lac st-jean
    161
    Well ill look at my head nut torque but im pretty sure gasket is blew
    Tri-z 1985 resto project
    Arctic Cat Prowler 440 90 --- raised handlebar -Homade cherry bomb exhaust ! - Custom Tuck tape seat cover - Sled Mod by SREDNECK
    Kawasaki Z1000 04 -- Offmarket front disk - Yoshimura tr-s carbon slip-on- Bmc air filter- Power commander 3- Airbox Mod- Inc flasher tail light-Action pro steering damper-
    IM FRENCH so sorry about all thoses grammar mistake o.O
  2. #32
    tippmann's Avatar
    Nov 2005
    161
    I Borrowed a keihin 35 mm flat carb that my friend had on his banshee before he start running with only one carb. i put a 170 main jet in it and DAng !!!! too rich !!!!!!!!!!
    Before testing out the carb i matched the intake with the carb size( to not choke) then matched the v-force stuffer to match the intake hole( again to not choke).
    SO now with the carb test im 100% sure problem is from carb... But now the only thing in the carb that could stop me beeing more rich is the needle jet. i Presently have a 480,Q-2 with a 6fj41 needle.. Every needle jet cost 17 $ and if it dont work i cant return it.. so wich one i should try out ??? Q-6 ? Q-8 or go in the R1, R2 ??? Thx for your help...
  3. #33
    tippmann's Avatar
    Nov 2005
    161
    Yesterday i saw that the 6f4 needle is 62.3mm long and the 6fj41 is 68mm but anyone know if mikuni flat (tm) use same needle of the vm (round)? I know the needle jet of tm is longer that why im not sure about needle shorter. Was about to test it but the adjustement screw in the middle of the clutch broken ,,, so i have to figure out what to do with this screw
