Results 1 to 7 of 7
Thread: Atc 70 exahust RED HOT???
    Wisconsin
    118
    I have a at 70 and bought a sterdy exahust put it on a year ago without no problems now its not running so good took the carb apart thinking maybe some dirt inside that was perfect took it out for a ride last night and noticed that where the exhaust attaches to the head 6 inches of the pipe was RED hot! then when i would slow down then it goes away just when i open it up???
    6,813
    Motor is running lean . Do a plug chop .
    Wisconsin
    118
    Maybe I might have to go 1 jet size bigger if the plug is white or gray when i do the plug chop
    Jan 2011
    Brazil, Indiana
    2,087
    Valves might not be closing all of the way. Maybe a cracked, or bent exhaust valve too. Definitely worth looking into.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Sarnia, Ontario, Canada
    3,415
    Spark timing issue or possible exhaust restriction could also be the cause.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    THATS AN EASY ONE... its been running great for a year.... and now its not.... the block on the the points is wearing down and changing your timing ... its retarding it to the point that you going to burn it up .... new points will fix the problem,,,
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Did you check your oil? After a year, it might have dripped some
    My 200X did the same thing when I put a chinese carb on it. Had a 95 main, but stock its running a 110. To heat the exhaust red hot you need to be REALLY off on jetting. If you did not change carb and its clean you might wanna check somewhere else.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
