Anyone have any idea why this could be happening ? If i hit the gas, it will try to pull the right very hard.
Tire pressure, bearings, bent forks? Few things to check. Good luck.
1986 ATC 250r
1985 ATC 250r
1985 X2 ATC 70's
1985 XL 80
Tire pressure.
86 250sx - old reliable
another 82 110
-gone but not forgotten-
82? 110 - why did i sell it??
84 225dx - meh, it was a pile
your swingarm bearings are bad and when u hit the gas the chain pull angles the swingarm along with its sprocket to the right. Also check axle bearings while u are at it with rear end in the air
86 T3
84 T3
86 KX250
Don't forget rear brake dragging as well.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
I'm betting just tire size/pressure.
Bent frame? My 350x had a bent frame, it was not really noticeable looking at it but it was slightly tweaked and pulled to the left all the time.
OOOOOOOooooo what if the frame is cracked.... ya ya that could do it too.
I would start with the tire pressure and then move on to the bearings next........
3 Wheelin' and 2 Strokin'
i highly doubt it, but could be the hub stripped out possibly. no splines on one side would basicly give you one wheel drive. i've seen it happen once before and it was on my brothers tri moto many years ago. hit the gas and it pulled worse the more power you gave it.
It happened to me. The axle was shot, out of round due to bad carrier bearings.
I found that out the hard way. I hired dirt crasher to rebuild the entire rear end.
I never saw anyone tear down and rebuild so quick and good
LoL Good for you steve $$
♠ 58 ♠▓
▓ ▓Ride 3
I am so poor now I cant even pay attention .........
^^^I was wondering the same thing. ^^^
It was something that I had seen once a while ago. There was more to it than that, bad bearings as well, but it was on a totally neglected trike.
Nicholson 185s
