Results 16 to 30 of 32
Thread: Is this a Honda 200 or a 200S or ES?
    Mar 2007
    Texas
    5,045
    go get a new one. if you buy a craftsman instead of the autpzone crappos it will last and not break on you. the cheapo ones break.
    ________________
    https://www.mikesatvfix.com
    Apr 2009
    Oklahoma
    1,234
    I got it out.
    anyway I am to a point where I am stumped I have the manual right here in front of me and did a forum search. I cant for the life of me get this crank shaft apart???
    am I missing something? Do I need a special puller to get this off? is it threaded on?
    Jan 2011
    Avon, Minnesota
    641
    that my friend is a flywheel. all flywheels are held on a woodruff key which needs to be pulled off with a puller like all flywheels.
ID:	146650 Right here in the manual.
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Apr 2009
    Oklahoma
    1,234
    What is the center going to push on it's inset about an inch???
    Jan 2011
    Avon, Minnesota
    641
    thats why the puller is about 4 inches long.
    Apr 2009
    Oklahoma
    1,234
    I know But the only pullers I can find the shafts are to big to fit inside there. I thought the flywheel was right underneath the pullstarter I have the bolt puller set for that one...
    Apr 2009
    Oklahoma
    1,234
    If I am not mistaken I will be needing some of these...
    Jan 2011
    Avon, Minnesota
    641
    if you have a inch or more clearince between the flywheel and the cases you can use that type. they use the regular screw type puller in the manuals
    Apr 2009
    Oklahoma
    1,234
    I dont have anything to screw into... like I said before the other one comes off but it had screw holes for my puller to screw into...
    Mar 2007
    Texas
    5,045
    http://www.motionpro.com/motorcycle/partno/08-0026
    right tool for the job. if your threads inside are srtipped or missing then, you have to use a standard gear puller and it's a pita!!!!
    ________________
    Mar 2007
    tx
    109
    You need a special puller. Part of the puller threads into the flywheel. The forcing screw pushes against the crank. Go look at some on ebay, u will see what Im talking about. Ive got to get one for my warrior too. Good luck.
    Apr 2009
    Oklahoma
    1,234
    DAM that sound's Like it's going to be a challenge to find!
    Apr 2009
    Oklahoma
    1,234
    Is there a special name for this puller?
    Mar 2007
    tx
    109
  15. #30
    Apr 2009
    Oklahoma
    1,234
    Quote Originally Posted by oscarmayer View Post
    Thank you oscarmayer
